New Wolf's Head ATF for ZF Transmissions only $5.88/qt
Old 01-03-2011, 06:58 AM
maxthrottle's Avatar
Default New Wolf's Head ATF for ZF Transmissions only $5.88/qt
I was in the Advanced Auto store and I noticed that Wolf's Head is making a new ATF that is compatable with ZF Transmissions it's only $5.88/quart! I had the counter man pull out their Wolf's Head factory manual to double check guaranteed compatability. Looked offical to me, after all the posts about this fluid worth its wait in gold I'm having trouble believing this. Has anyone used Wolf's Head AFT?
Thanks,
Bob
Old 01-03-2011, 07:34 AM
Jon89's Avatar
Received 4,405 Likes on 2,876 Posts
Thanks for posting this information. Looks like those of us who may be interested in alternatives to ZF Fluid (Lifeguard 6) have some additional research to do....
Old 01-03-2011, 07:50 AM
Jon89's Avatar
Just perused the Wolf's Head website (wolfshead.com), and saw that their synthetic ATF meets the Shell M1375.4 specs required by ZF. Also saw that it is compatible with the 5-speed ZF, but saw no references to the 6-speed ZF that those of us with 2003-and-newer S-Types have. I will e-mail Wolf's Head and ask them directly if they have a new product that meets the 6-speed ZF's requirements. Stay tuned....
Old 01-03-2011, 08:13 AM
Staatsof's Avatar
And who in the heck is Wolf's head? That's new one ...
Holtl1 (02-23-2012)
Old 01-03-2011, 08:24 AM
Jon89's Avatar
No, they're not new at all. Probably been around for 60 years or more. They're in Florida....
Old 01-03-2011, 08:32 AM
Staatsof's Avatar
OK, then not widely known. Since 1879 IS a hell of a long time ...
Old 01-03-2011, 10:10 AM
Default Specs for new Wolf's Head Synthetic ATF
Here are the specs from the Wolf's Head website:
http://www.wolfshead.com/specsheets/...lsynthetic.pdf
Note the Jaguar AF 5HP24 Transmission is listed. But the AF6HP26 is not.
So the AF6HP26 is used on 2003 and newer? Is it much different than the AF5HP24?
Old 01-03-2011, 11:54 AM
vance580's Avatar
The AF 5HP24 is a 5 speed trans and the 6HP26 is a 6 speed. They are pretty different. I had a 5HP24A in my Audi and they are pretty bad and known for early failures in the Audi platform. The 6HP26 has a much better reputation. I'm not sure how the fluid specs are though. I do know that the 5HP24 did require the mineral style ZF fluid.
Old 01-03-2011, 01:37 PM
Default New News from Wolf's Head
Just called Wolf's Head Oil company and spoke to their Senior Product Specialist, he told me that their synthetic oil is completely compatable with the Jaguar ZF6HP26 Trans as well as the ZF5HP24! But he wanted to be certain and double check with their chemist, he called me back 10 minutes later and said they would stand behind their ATF for the ZF6HP26 trans. The Wolf's Head Synthetic ATF has Shell LA 2634 cert wich translates to a Lifeguard 6 is can be used in Jaguar S 2003 as well as BMW 745i 5,6 and 7 speed transmissions (Is this the same trans as the S ?) This stuff is only $5.88 per quart retail!
Wolf's Head Oil Company Tampa FL. 813-569-8106
Old 01-03-2011, 01:54 PM
Michael Star's Avatar
WOOT! Great work!
Old 01-03-2011, 02:23 PM
JagV8's Avatar
Received 4,564 Likes on 3,968 Posts
Good news! Though, I don't really see how it can be suitable for both the ZF 6HP26 and 5HP24, as the oil specs are different.
Various BMWs use the 6HP26 (and have "the lurch" too).
The Aston Martin DB9 and Maserati Quattroporte use the same box, and I understand the Ford 2005 Explorer also does. (There are others, too.)
Old 01-03-2011, 03:14 PM
Perhaps the synthetic ATF can meet the specs of many different mineral and petroleum based ATF's? I don't know. It was easy to get ahold of people that sounded like they knew what they are taking about...a human being answers the phone! I'm going to buy a new pan and O ring thngy kit and a case of this oil, print out the instructions from this forum and let my mechanic change the fluid in the 2004 S. It has developed a squeek when it upshifts.
Bob
Old 01-03-2011, 03:26 PM
JagV8's Avatar
I was kinda asking the question (thinking out loud if you like). I don't know enough about tranny/oil/etc to know if it's possible or not. The price is very good and sure makes it worth taking seriously. Wonder if it's available over here.
Old 01-03-2011, 03:52 PM
Riski's Avatar
Bob
Why are you buying a new pan?
Old 01-03-2011, 04:15 PM
JagV8's Avatar
I'd guess because it contains the filter and is also prone to warping and/or cracking.
Old 01-03-2011, 04:46 PM
clubairth1's Avatar
Received 2,491 Likes on 1,952 Posts
maxthrottle:
Have you seen this TSB for the noise?? The fix is to change the fluid twice. Let us know how the Wolf's Head works out. I will look for some.
Old 01-03-2011, 06:07 PM
Riski's Avatar
hmmm never knew that....how much do they go for?
Old 01-03-2011, 08:00 PM
Jayt2's Avatar
Received 22,600 Likes on 8,996 Posts
Question...if an oil is spec'd for the 6hp, then would it be good for the 5hp? That is, going from a "higher" level of usage to a "lower" level.
Also....if an oil is good for the 5hp, then it may not necessarily be good for the 6hp ??? That is, going from a "lower" level to a "higher" level.
Or did I just cornfuse the hell out of myself???
Old 01-03-2011, 09:47 PM
aholbro1's Avatar
Received 1,645 Likes on 1,069 Posts
Rock auto has the pans (listed under "filter") for $100-n-change
Just had a fluid/filter change done on the 2003.
Old 01-04-2011, 02:31 AM
bogart's Avatar
You can easily backflush the filter. And why they should be prone to warping and cracking is beyond me as they are made of substantial plastic. I've not heard of anyone with a cracked one or a warped one.
Quick Reply: New Wolf's Head ATF for ZF Transmissions only $5.88/qt
