Newbie with a couple of serious questions
Old 02-11-2011, 12:17 PM
achysklic's Avatar
Another update:
Replaced the drivers rear wheel bearing and car is quite as a mouse
Replace DCCCV it looked horrible, however still only blows out hot air. I am pretty sure the Climate Control Module has a burnt trace or two. I amd gonna pull it out later today and see if I can solder it.
Thanks guys for all the help so far
Old 02-11-2011, 07:12 PM
achysklic's Avatar
Ok I took out the DCCV it had atleast 2 burnt traces which I ran a jumper across. I put the unit back together I get some cold air now.. However,there still is very little hot or cold air clowing out the vents.
I can hear the air blowing hard iside the dash but very little comming out no matter what settings I put vents on.
Any suggestions? Could it be blender door motors?
Old 02-11-2011, 07:24 PM
aholbro1's Avatar
Received 1,642 Likes on 1,068 Posts
Not sure about the S-types, but the climate control on my XJ has a self-diagnostic that is activated by some combination of button-presses I've never tried and can't remember offhand, but if it finds malfunction codes it displays them on the climate control screen. Maybe check your manual and see if such a check is described? If so, a failed flap actuator or stuck flap should throw a code. Not sure about the blown traces, though.
Another cause for lots of blower noise and little air would be a clogged cabin air filter (engage the recirc button and see if your airflow changes, at least your noise should change a bit) ....or...less likely, unless the PO pulled your cabin filter and chucked it....the face of your evaporator and/or heater core could be clogged with hair, dirt, fabric, foam.....whatever....
Old 04-04-2011, 02:37 PM
nemw001's Avatar
When driving at road sped - 45 - 55 mph ish -- swerve to right and left -- be sure no one right on your heiny -- and see if pitch changes when loading up the bearing assemblies - if it changes noticably either way remove wheels on that side in rear colapse brake calipers and rotate hubs - can you feel / hear anything at all ?? if so probably need hub / bearing replacement - do yourself a favor and replace both if one is gone - I sure hope I'm not being redundant here.
Steviedee1st
11-28-2023 06:32 PM
Forcedair1
05-14-2023 03:28 PM
WinterJag
16
10-09-2015 07:49 PM
b1mcp
09-13-2015 07:31 PM
teacoff
09-10-2015 08:25 AM
Quick Reply: Newbie with a couple of serious questions
