Nextbase 312GW Deluxe Dash Cam
I drive an S-Type 3.0. (2003). I just bought a Nextbase 312GW Deluxe Dash Cam and also the Nextbase Car Camera Hard Wire Kit. I was surprised how easy it was to conceal the power cable of the Hard Wire Kit behind the trim. I've managed to get it invisibility all the way from behind the rear view mirror (where I mounted the camera) to the fuse box in the driver's foot well. I mostly only used my fingers to gently pull on the trim and allow me to guide the cable behind. Occasionally I used a flat-headed screwdriver to prise. From the top of the A Pillar I brought it down behind the door seal and then behind the air bag at the side of the dash. Then underneath to the foot well. My biggest headache was that the fuse box (inner) cover did not want to slip back on once I fitted the piggy back fuse connection. I've had to hold it more or less in place by re-fitting the outer fuse box cover.
