no air from vents
Received 6,307 Likes
Maybe it would help if you kept all the heater/ac problems in one thread.
https://www.jaguarforums.com/forum/s...r-pump-156964/
https://www.jaguarforums.com/forum/s...-doors-167686/
https://www.jaguarforums.com/forum/s...-doors-163327/
https://www.jaguarforums.com/forum/s...oblems-161761/
https://www.jaguarforums.com/forum/s...estion-162095/
So why not start at the beginning and tell us what the problems are and what you have done.
Bought this car awhile back with a myriad of problems. Replaced the dccv, the auxillary water pump, the hoses underneath the supercharger, thermostat replaced, transmission drained and filled, and much more.
It had no heat when I picked it up. After dccv and aux water pump replaced, plenty of heat, but no A/C.
Checked everything according to jaguarclimate.com, everything checked out. Rccm soldered, still no A/C, blew hot air. Took rccm to another guy, removed soldered points and used a conductive pen on burnt traces. Put it in, now no air blowing and compressor continually runs, with or without the key in the ignition. Replaced clutch relay, still runs. Pulled #32 fuse, stopped running.
That is where I am at.
