no hid headlights
Switch in the collum? (Forget the correct name, but the thing that fails a lot and is talked about a lot on here... all the buttons for the wheel go through it... figure it out yet? lol That thing) Not sure if the control goes through that or not but regardless check the switch.
Did you see if the voltage changes at the lights yet? BTW, just cause the relay clicks when putting it in, does not mean it is working properly. Just means it IS getting power, but is it sending it? Multi-Meeter will be your friend here.
Both not working means something common is at fault... switch, relay, fues, ground...
Edit: you posting from a phone? If so, Mods, why can't we add Sig's from phone?
Fletch44
09-28-2015 02:21 PM
