No power or acceleration
Have a 2000 S type base model. It went into limp mode. Towed to a mechanic who then proceeded to find the intake gasket bad, replaced the gasket, new spark plugs but has no idea why the car has no acceleration or power. Can put it in drive, or any gear, and push the pedal and no response. Will work in reverse but not drive. If it does start to go, it is sputtering, sometime it will rev the RPM, but nothing else. He has thrown up his hands, but thinks that it might be the Throttle body, but he said that he cleaned it. Spent $1500.00 and the car will still not run. Any ideas what part(s) I should replace.
Tony
Tony
Jaguar is a 2000 with the base engine (V6 3.0)
The car does not move when gas is applied. Does go in reverse. Tried drive, 2,3 and 4th gear, but no luck. The throttle body was cleaned, and the O2 sensors check OK. New catalytic converts were just installed also.
Tony
Tony
Start it up, and push on pedal, engine will not rev or do anything. After about 5 minutes, the engine will start to rev, but only up to 3000 rpm, then it seems to almost backfire and goes down to less than 1000 rpm. I can rev it back up to 3000 but once it hit that level, it just goes down to 1000.
hen555
09-07-2015 11:13 PM
