noisy manual transmission when shifting
hello
my car sometimes makes a noise "clac" when i shift a gear, always from short to long gear (1 to 2, etc), never in the other direction.
i have the impression the sound is less present when the car is hot, and it vanishes if i drive "like an elderly man", spending time while i shift gear (for ex using the clutch smoothly)
while driving the noise always occurs when i engage the clutch, never when i disengage. I also found out the noise occurs sometimes when the car is stopped, neutral gear engaged, i disengage the clutch, shift to gear one and at that moment i can hear that sound though the clutch is fully disengaged...
i think there is an issue because im used to driving manual trans on many different cars, so i'm not "brutal" with my car !
do you have any ideas about how to solve this problem ?
thank you very much
thank you very much
Received 2,263 Likes
aholbro1
08-05-2021 05:02 AM
