noisy rear suspension.. common causes?
I have had this noisy rear suspension problem for a long time.. It's getting worse and I want to nip it in the bud.. my question is what needs to be replaced.. I bought the rear stabilizer links and was going to buy the tie rods as well and tackle them at once. I decided to change these parts because they are the cheapest components out of all my guesses, But before I do this and still have the same problem, my question to the more experience people here is. are these components known for causing the creak/squeaking sound over bumps and hard turns.
Thanks.
Thanks.
Here is some help in replacing:
https://www.jaguarforums.com/forum/s...80/#post356251
This may help as well:
https://www.jaguarforums.com/forum/s...deo-faq-68290/
Sonspit (02-25-2015)
Here's some from ebay. When I got them replaced the shop we took it to charged an hour labor and got both sides even though only one side was making noise. Figured if one side went, the other was soon to follow. Good luck.
Jaguar s Type Rear Lower Control Arm Fluid Hydrabushes Bushing Bushings Set 2 | eBay
Also they told me I need an alignment after it's done too? Is that required after re & re lower rear control arms & stabilizer links?
With that quote I really don't trust anything that shop says now but they also said it needs radius arm bushings which I am not sure what they are exactly? And they told me the upper control arm bushings are going to be ba soon as well and I might as well get them done too - again I find it hard to trust anything they say and will get a second opinion.
I also have the sway bar links already and I plan to buy the stabilizer bar and rubbers as I figure I might as well do them at the same time.
I bought some replacement bushings (3 per control arm) for the rear lower control arms as I also have the terrible creak/squeak but when I took them to the shop and asked for a quote they told me the labour alone to remove/replace the lower control arms would be 2 hours per side and another hour to press the bushings in and out. Total 5 hours labour for both sides and the parts were $300 so over $800 just to replace bushings??? I was just going to do it myself after I got that quote but I'm glad to hear you got it done for both in one hour I will definetely shop around for another estimate. I'm thinking perhaps a place that specializes in suspension might be better than a generic repair shop?
Jumpin' Jag Flash (03-22-2015)
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Trying a bit of preventative maintenance yesterday on the bushings for the rest of the car.She is getting up there in age after all. I sprayed ATP AT-205 over all the bushings in the front and back after a good cleaning now that winter is over. Figured I was taking the wheels off anyways to put on the all seasons back on and changed the brakes to ceramic ones. The Brembos really collect brake dust. A friend of mine told me about it after the rear lower control arm bushings were replaced, of course. I would have tried it first after his story of not replacing his and just spraying this on his bushings that were squeaking. Now I am noticing a difference, a big one in fact. The ride is smoother and feels more luxurious for $10. Will it last? I don't know.
Jumpin' Jag Flash (03-23-2015)
Richard_gib
09-12-2015 07:08 PM
