Now another problem!!!
Old 08-21-2014, 07:13 AM
clubairth1's Avatar
Received 2,351 Likes on 1,851 Posts
Along the same lines. I have found Propane works good too. I point the unlit torch around the area in question. Also no mess!
Jumpin' Jag Flash (08-22-2014)
Old 08-21-2014, 08:07 AM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
Originally Posted by earico
^ Yep. Tried and trued vacuum leak finder. I use carb cleaner. Engine idles up then you found your leak. Old school for the win.
It can fail to find some leaks but is otherwise OK if used with caution (ventilated space is wise!).
I suspect it wouldn't find a small leak in the hose buried under the intake in a 2000MY 3.0, yet you'd see there was a leak via OBD live data.
Old 08-21-2014, 10:14 AM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
I use Throttle Body cleaner it is a lot safer.
Link http://www.jagrepair.com/images/Auto...otos/P0171.pdf
Clamdigger
09-12-2015 03:43 PM
mcdutch
09-04-2015 03:38 AM
obwoodie
09-03-2015 07:45 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: Now another problem!!!
