O2 sensor location
I think these are before and after the cats, in the exhaust system.
Dave
the beagle (07-03-2013)
They are. Get under car and look up. The pipes parallel to the ground are exhausts, the angled heading up out of view are the cats and you can see things a bit bigger than spark plugs sticking out with wires - those are the O2s.
If tempted to do anything bear in mind they are DIFFERENT types front & rear and must be the right types. Also, they are commonly in VERY tight. You can check them using OBD - no need at all to get under the car till you've done that. Cheap OBD tool like ELM327 about $10 amazon or ebay.
Not sure of your model but this sight has a breakdown of codes and links to parts. Also there is a diagram in post 4 above.
jaghelp.com: Jaguar S-type Oxygen sensor codes: P0131, P0132, P0133, P0135, P0136, P0138, P0141, P0151, P0152, P0153, P0155, P0156, P0158, P0161
Brayen (12-26-2014)
The O2 sensor between the exhaust manifold and the converter is BEFORE as you labeled it or "upstream" and the O2 sensor after the converter is "AFTER" or "downstream"..
I have not taken off the oxygen sensors on my car. But after clicking (enlarging) on the diagram in post 4, you can see that 1 and 4 sensors (right and left) are before the catalytic converter and 2 and 3 sensors are after it. The legend in the diagram explains the numbers.
So, as I see it, you are right. Good luck.
Brayen (01-05-2015)
Guy-Pierre Boucher
09-16-2015 06:55 PM
KarimPA
09-12-2015 09:15 AM
KarimPA
09-03-2015 08:32 PM
