O2 Sensors
from amazon
Price: $35.09 & this item ships for FREE with Super Saver Shipping
Bosch 15716 Oxygen Sensor
This product fits your 2001 Jaguar S-Type
Engine: 3.0L V6 Gas DOHC Distributorless Naturally Aspirated SFI Electronic FI MFI
Notes: OE TYPE BEFORE CATALYST - USE OF THIS SENSOR RECOMMENDED, CAN USE SENSOR WITH LONGER WIRE HARNESS
Price: $35.22 & this item ships for FREE with Super Saver Shipping.
Bosch 15717 Oxygen Sensor
Notes: REAR - OE TYPE AFTER CATALYST
So with free shipping and no tax you can replace all four O2 sensors for $140.
THANK YOU,
They have been ordered and will arrive on Friday. Will keep you posted![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Guess I should state why I am changing them.
I keep getting DTC codes indicating banks 1 and 2 are running lean when running around town. After resetting the DTC and going on a long run the DTC light stays off, as soon as I start running around town again, on it comes.
Checking out all pipes, connections etc I did find one loose, not seated correctly. After seating it the Jag is running VERY rough, keeps stalling below 800rpm sometimes when taking a corner, dangerous, sometimes when at stop lights.
My Mechanic wants to swap them out thinking it is the front two. As I can get all four cheaply I might as well the rear set changed at the same time.
Mark
Mark
from amazon
