O2 sensors
Got all sensors ordered for less than Ł280 Not cheap but not as bad as expected
Need to sort before the WI gets fitted I'm sure it's not much Just a question of trial and error
O2 sensors done (with extenders on the post cat sensors) MIL and restricted performance cleared All fuelling related codes gone at last but.......... New code never seen before P2601 Going to check the charge cooler pump as that seems to be the likely culprit If the connection is ok will change the pump for an upgraded version Anyone know of any charge cooler radiators available for the STR? Seen them for the XKR but I think I've read that the STR is already bigger Any idea if that's correct?
Take a look at this thread. I just went thru some interesting O2 repairs on my 2005 STR. Brutal gave some advice I was not familiar with regarding the O2 error codes. I have the proper Factory Denso part number in that thread.
Got it for $78 including shipping.
https://www.jaguarforums.com/forum/s...6-p1647-86397/
