OBD Scanner Required
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hi All -
I was driving last night and the amber warning light kept coming on saying Engine Fail Safe - it would then disappear.
Then this morning I started the engine up and it went to Red warning light and no power.
Limped back to the drive way - switched the car off and then back on and the error had gone. ??
Couple of questions - any one else had this ?
What type of code reader do I need to get to read any codes .
I have a S Type 1999 3ltr.
Help
Help
![Icon Tinykitball](https://www.jaguarforums.com/forum/images/smilies/icon_tinykitball.gif)
Your issue with the scanner is a number have been found to be incompatible with OBD2 Jaguars and some will return false codes. The thread https://www.jaguarforums.com/forum/g...-%2A%2A-33347/ is a good place to check 'member approved' scan tools.
The last OBD1 standard Jaguar model I had was an XJ40. On the earlier OBD1 standard, fault codes were accessed by pressing the VCM button. Vehicles with OBD2 standard have a diagnostic port.
Exact changeover to the later standard varied between manufacturers and markets but was generally 1995/96. Broadly speaking, the difference is OBD1 only monitored entire circuits or components for failure whereas OBD2 monitors performance against a predetermined range.
Hi,
Is that your unit on ebay?
If not I would like to buy it from you, if the other member does not want it.
At £10 thats a good deal.
regards
Stan
regards
Stan
£10 its one of them elm 327 bluetooth one's.
check your car is OBD2 First
Bluetooth Elm327 Scanner OBDII OBD2 Diagnostic Scanner | eBay
