ODB codes
ODB codes
Hi, I have a Jaguar S type 3,0. Everything started with the ODB code P0160 "02 cesor cicuit, no activity detected bank 2 sensor 2". I changed all lambda sonds on both cylinder banks, just in case.
Now there is another OBD code thats showing up: P0174 "system to lean bank 2". I have been looking for vacuum leaks, but are inable to find any. The car has a normal idle but as soon as I accelerate it hacks, but it don´t seemes to missfire.
Is there anyone that have an idea where to continue to search after the problem?
I´ve done a reboot by disconnect the battery for some hours after erased the code with my OBD2 reader. My wife used the car for going to work, (about 40km), and no sign of any errors, like Engine lamp and the orange lamp. When starting the car for going home, both lamps lit. When she arrived I took the car erased the code and drove about 10km and I accelerated both with and without kick down, turned of the car and started it without any problems. It feels strange because the car runs as there is nothing wrong with it, except for the warning lights. Right now I´m charging the battery, (even if it seems ok).
The error code P0174 have appeard again. I´ve checked for vacuum leaks and are unable to find any. Idling is ok and no rpm variations. I really suspect an electrical failure as a poor connection somewhere. Working with electrical systems on cars is something really I hate, (except for 2CV:s that have four glass fuses only). Is there anyone that have experienced a similar scenario?
I´m afraid of unravel the thread from the wrong direction, because of the unnecessary cost it would involve.
The P0174 code is for bank #2 and the lack of P0171 bank 1 leads me to believe it could be a fuel issue or an o2 sensor but it would be hard to identify without LTFT readings. I would first add BG44K to the fuel and see if the code clears.
Link to Codes http://www.jagrepair.com/images/Auto...TC_EOBD_R2.pdf
The problem is finally solved! It was an electrical issue, the cable from one of the O2 sensors on the left cylinder bank was broken. "A quick fix" so to speak and after rebooting the PLC in the car, the error code disappeared. So the gist of this story is to look for all simple things that seemes could be the cause of the error. Unfortunately I did not do that, but started with changing one of the O2 sensors on the left cylinder bank since the error code was P0160. After changing this sensor the engine lamp and the code started to appear in an intermittently way. I decided to change the second O2 sensor on the left cylinder bank, but the result where the same. When changing oil and filter in the gearbox I also changed both O2 sensors on the right cylinder bank. After this change of sensors, a new error code turned up: P0174 indicating that the mixture of the left cylinder bank was lean, and tha car went in "limp mode". Naturally this got me in to an electrical failure as a broken cable, since I´ve been reading a lot of technical information on this forum. It´s funny when you´ve solved a problem, with all the hindsight that appears. Thanks for all help.
hehe, "Norwegian reset" Feeling better already in the morning...
philwarner
25
06-26-2021 05:43 AM
