Oil cooler lines weeping
Old 04-21-2015 | 08:08 PM
Staatsof's Avatar
Originally Posted by 2004STR
Hey Bob,
There is one bolt on the auxiliary coolant pump that needs to be removed. Once you get that out the pump will move enough to allow you to get to the bolt for the dccv from the top, no need to disconnect hoses.
You also need to disconnect the harnesses under the car on the right side (same side as the dccv). There are only two bolts that hold the shroud in.
There's a decent illustration of the harness connectors in the workshop manual. I use the pdf manual far more often as I don't want to get my laptop all greasy. I assume there's a link to it on the forum? If not I'll post one. It's 64 mb and 3316 pages, covers everything the jtis does(at least so far)
Hope that helps!
Mike
Yes, please post the link to that manual. Thanks.
Old 04-21-2015 | 08:37 PM
2004STR's Avatar
Posted link in a new thread
Staatsof (04-22-2015)
Old 04-22-2015 | 05:12 AM
Staatsof's Avatar
Which thread, I don't see it in the one I started?
Old 04-22-2015 | 05:38 AM
2004STR's Avatar
I started a new one here:
https://www.jaguarforums.com/forum/s...manual-141406/
Old 11-15-2015 | 12:29 AM
mrlovt's Avatar
It may be possible to directly install a male fitting into the radiator openings. I believe the fitting is M18x1.5. I haven't tried it but the thread pitch looked right. You'd have to come up with some way of sealing it.
Let me know if you need more info
Mike
Did you ever verify the size and type of fitting that connects the lines to the radiator? I cross threaded one and need to find the correct tap and die. This on my '05 XJ8, but with the 4.2 it should be the same (or at least a place to start).
Old 11-15-2015 | 01:45 PM
2004STR's Avatar
Unfortunately I never did verify the size, I used the old fittings and spliced into the hard lines so didn't need them. I believe I checked the thread pitch and verified it to be 1.5 mm. I'm a machinist so I deal with threads all the time but can't say for absolute certainty.
Old 11-15-2015 | 09:25 PM
mrlovt's Avatar
Thanks for the reply. It seems you have a good eye. I was able to check with an 18mm 1.5 tap today, and it fit perfectly.
99xk8guy
05-28-2024 09:36 PM
mrplow58
01-21-2024 05:53 AM
silkcat
04-15-2023 04:58 PM
SouthernGypsy
09-23-2015 04:06 AM
Busa R
09-10-2015 07:28 PM
Quick Reply: Oil cooler lines weeping
