oil leak
Yes. The two intake manifold tuner valves (upper and lower) have yellow-colored O-rings that tend to fail on every V6 engine. The fix is to replace them with the new-and-improved green-colored O-rings. They are thicker, rounder, and create a leakproof seal. There are many threads on this forum that will take you through the installation process. Simply search "intake manifold tuner O-rings" and you'll find all the information you need to know to do the job yourself. The two new O-rings should cost between five and ten bucks, total, at the Jaguar dealership....
I'll help you along:
https://www.jaguarforums.com/forum/s...ics-faq-32135/
and if you miss the link in the opening paragraph:
OkieTim
09-08-2015 04:48 PM
