Oil life monitoring system on 04 S Type???
Not that I know of. I just did the 20thou service on Laurie's since we don't know if it was done or not.
Not to hijack but speaking of dealer service. I do know that the PO of this car had it serviced at the dealer. Year old Jag battery in the trunk, Jag oil filter and the rep at Rahal ran the VIN and said it was in once a year.
So I go to take the belly pan down and the frt center J-nut spins, ripping a chunk of plastic with it. I fixed it up with my trusty Fusor Adhesive good as new. But then I noticed nothing holding in the middle although there are two holes where fasteners should be. They had snapped the studs off the two little tin retainers in the center and just left it that way. I'm going to see how expensive a couple new one are. I can't imagine a whole bunch.
But why on earth wouldn't you put some antisieze or grease on those fasteners when you know they rust up. Well at least here they do. Especially when you are the one that will have to deal with them next time. And why let a car go out with fasteners missing out of the belly pan. Of course they probably figure just let it fall off and then sell a new one.
I don't mean to bash dealers but I bet an oil change isn't like Jiffy Lube priceing.
Oh, and I am surprised that this Jag doesn't have a service interval reminder. Such cars as my lowly Saturn wagon and a couple Pontiacs I had tell you when to change the oil. Just kinda surprising given all the other electronic do dads. Also got a surprise that it holds 7 quarts of oil. I wondered if it was ever gonna quit draining!!
All good points.
But I think only the diesel has a service / oil change reminder (with other messages) - all due to diesel-specific issues (DPF, oil/fuel dilution, whatever). And thus also has a way to reset the reminder.
As the non-diesel cars with VVT really do like clean oil it's a bit surprising there's no reminder.
Was there a line item for "blue writing fluid" aka "ink"? The service order had to get written after all and old dried up "blue writing fluid" doesn't work as well as fresh "blue writing fluid". But, if they want to change to green, red, or black ... a full flush is required to avoid cross contamination. And of course, regardless of colour, it has to be genuine Jaguar "writing fluid" meeting Jaguar specifications and only used in a genuine Jaguar "writing fluid" reservoir.
You're probably getting the drift by now.
BrentGardner
28
04-26-2024 03:08 AM
xjrjag
10-27-2021 11:48 PM
stanjag
08-30-2015 10:35 AM
