Oil pan drain plug torque specs?
Greetings!
I recently had the engine oil and filter changed on my 2005 4.2L V8 S-Type. Due to the cold weather and snow conditions I elected to take it to my local mechanic in lieu of doing the change myself. This would be the first oil change since I purchased the vehicle so I have not yet had the experience myself. After reading recent postings on the general subject it appears that the drain plug has an "O" ring that should be replaced. Is this correct? Hopefully the mechanic did replace it - do they normally come with the oil filter?
After approximately 2 weeks I noticed a few drops of oil on my driveway. Naturally I will take it back and have them look at it but the question is.........
What is the torque spec for the drain plug? How tight should the oil filter be?
Thanks in advance,
Thanks in advance,
Gerard Radimaker (02-01-2016)
+1 (but note that's kinda snug rather than very tight! - a leak is more likely from over-tightening for most people, I reckon)
If the O-ring is OK you can get away with not changing it if you don't over-tighten. I don't know how many times you could keep reusing it.
I am hoping it was not over-tightened and just needs to be snugged up but was curious as to factory specs. Of course without getting it up in the air and removing the belly pan [seems rather easy] the oil could be coming from other places. The only times I actually use a torque wrench on drain plugs and filters are when changing oil on my motorcycles.
ladxk8
02-02-2016 05:45 AM
