Oil pan leak
ok guys, I think Im about there, I loosend up the alt and ac bolts but did not completely take them off because It looks like I have enough room to take down the pan now all thats left is to lower the stearing gear and raise the engine. Im a bit stumped on lifting the engine, I don't know where is a safe place to attach the chains. I was thinking of wrapping them aroung both exhaust manifolds but wanted to ask If this is a bad thing to do because Im worried I might break some thing by doing it this way.
Received 2,192 Likes
DavidRey (04-17-2011)
So brutal it is ok to put all the engine weight onto this area? I was wondering about that the first time around...
I thought you where talking about the two exhaust manifold bolts. theres one that holds the dipstick in place and there is one on the oposite side of the engine.
Received 6,324 Likes
If it doesen't put too much stress on the bell housing it sounds like the easiest way to go.
#30
#31
brutal I tried it with a jack and peice of wood but the jacks did not rase it high enough. what do you recomend I do now? I was thinking of wrapping the chain through both exhaust manifold and lifting it from there. other than that I don't see another way. will I risk breaking the exhaust?
#32
YOU meen you ran out of jack lifting height?? I guess you dont have a jack saddle extension either
what about cutting a 4x4 off to make an extension, you only need to jack it up to get the pan on/off. And as I mentioned earlier, the trans upper bell housing and cats hit the tunnel and underbody so you cant lift the engine/trans higher. But this is enough to get it out, that is if youve also dropped the steering rack away from the frame cause the back of the oil pan hits it if left attached
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
#33
ok guys so I lifted the engine up but now I cant realine one of the engine mounting brackets on the stud. the bracket is resting on top ot the stud but I can see half of the stud through the bracket hole. Can any body give me an idea how I can get it down? I lifted it back up but still having a hard time getting it right on.
#34
It's all good then I was thinking about the engine being cantilevered on the bell housing bolts.
It doesn't always pay to think too much.
The mountings are flexible, you will need to use a lever of some kind to pull it into line.
![Icon Playing](https://www.jaguarforums.com/forum/images/smilies/icon_playing.gif)
#35
#36
thanks for the tips guys, ok so know I have the pan off and i'm looking at the connecting rod bearings because I stated before in another thread that I was hearing some sort of ticking or pinging noise. What exactly should I be looking for? I felt all rod bearings caps and I can wiggle them just a little and by little I mean VERY LITTLE. Is this normal? all of them are like this.
#37
#38
Thanks brutal, If I had a rod bearing problem how would I know just by looking? I've watched many videos on youtube on spun rod bearings and they all seem to have up and down movement, mine do not. So does that mean I don't have to wory about it being a bearing problem? I also looked for metal pieces and did not find any chunks but some tiny flakes like much much smaller than a grain of fine salt but It's not like the pan was full of tiny metal flakes I REALLY had to try and find them by sweeping my finger around the oil pan but didn't find much if none at all. Is this just normal wear or indication of a problem. Thanks
#39
To be sure the only way to know is to pull the caps off 1 at a time and them the mains and inspect the bearing halves. Since most bearing loading is to the bottom shell thats would be where the first signs of damage will be. But youre asking questions that i know if you take down the caps youre gonna need to take pics because youll not know what is normal bearing wear and what is a problem. Some are very obvious, others are well, maybe i should put back together and sell. Personally i doubt you have a issue, there are lots of things in the engine that tick and are not an issue
#40
To be sure the only way to know is to pull the caps off 1 at a time and them the mains and inspect the bearing halves. Since most bearing loading is to the bottom shell thats would be where the first signs of damage will be. But youre asking questions that i know if you take down the caps youre gonna need to take pics because youll not know what is normal bearing wear and what is a problem. Some are very obvious, others are well, maybe i should put back together and sell. Personally i doubt you have a issue, there are lots of things in the engine that tick and are not an issue![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
