The ole' coolant leak under the supercharger
#41
#42
You've done this repair?
I can see dropping the EGR if it's not needed but most the rest of the stuff probably isn't going to be found in the after market. If the bolts are vanilla stuff OK.
Does replacing the EGT require almost as much labor and new materials so it becomes a "you might as well while you're in there" situation?
The DIY labor is probably a weekend if you have everything available and you don't run into issues.
That's really sad for a Jag design induced frickin' hose failure.
This one has me re-evaluating long term ownership.
There are a number of other quirks as well.
The transmission service issues on this vehicle sounds like a PITA.
The heater control valve.
I dunno guys ...
I dunno guys ...
#43
I can well understand your worries about this one hose. I suppose it didn't occur soon enough for jag to re-engineer it, shame though that is.
The trans service is just like many others now. Sad but true. And it's akward, but by no means impossible. Fluid price has dropped to bearable.
The DCCV is daft but there are similar or worse goofs on so many cars........
If there's a perfectly reliable car with neither manufacturing nor design defects, it's probably soulless.
#44
#45
The very definition of a "Hose Job"
I haven't looked to see if it's just this edition of the SC engine or if the earlier versions had a better solution for this hose? Maybe they introduced the problem with the hose size change technique they utilized? It's a surprising failure to me.
I get surprised from time to time. I had the OEM replacement water pump fail on my 1999 K2500 Suburban (a big monster of an SUV) after being only 2 years old. Someone did something wrong in the manufacturing of that one too.
I have plenty of cars with soul. Maybe too many ...
Has anyone charted when this issue crops up by miles or years?
Modern cars have become very expensive to work on.
This one is just as big of a PITA to change the oil on as my Infiniti was with the whole belly pan thing. How about an operable flap in just the right spot that's 2 minutes to open????
OK enough griping for now ...
#46
The EGR valve was definately a "might as well while its out" descision. It did look corroded on the inside which would probably prevent it from spinning in the future.
One fun thing happened yesterday. Went to a touchless car wash, on the way home, BAM, limp home mode. Pulled into a parking lot, shut it down, locked car, then started it up and it was fine for the rest of the day with no CEL. I have already gone through this throttle body/moisture/limp home mode monstrosity years ago.
Would they have had to mess with the throttle body when making this repair or could it be something else?
#47
So, its perfectly valid to note some of the other items as being overpriced.
Particularly that thermostat gasket at $73. Not the thermostat, just the gasket. The Gates thermostat comes with the gasket and is under $20. At least that was the situation three weeks ago, anyways.
#48
Well, you thought the "coolant price is a total rip off."
#49
I know the wound is still very sore but did you find out where the failure point was on the old hose? Pictures?
#50
Did you miss the part that the bit*h threw itself into limp home mode after a car wash?
The bill is just a minor detail after this thing threw itslf into limp home mode. To top it off the wife hit a pothole tonight and the passenger side headlamp failed/broke and was aiming down the whole way home from the engagement party we were at. I am not a happy Jag owner at the moment.
#51
#52
No I didn't miss it. Is it better again?
I think I can sense what's coming next.
You can fix the headlamp via the cheapo route. I wouldn't go to the dealer and even ask about that one right now. Fortunately both of those got fixed under warranty on mine.
I dont have pictures but I will find out the exact information on where the failure occured. Again, the EGR valve looked like a coroded POS and it needed to be replaced.
#53
#54
#55
just had this one did a few months ago, also did all the other hoses under the S/C while it was off. Charged 6 hours labor + parts ended up being $650.
while i was disappointed at doing this of course, especially after just months before having some other coolent hoses done I felt blessed it happened at home. I had just returned from a weekend trip to naples (4 hours each way) and hadnt had it on a road trip in a long time. I would have hated trying to get it back by having to stop n refill the thing every so often!
#56
Was that at a dealer or an independent?
If it's an independent were they already familiar with doing this repair?
#57
a large independent shop, the technician has been doing jaguars for 20+ years, vintage and modern. The book says 6 hours labor I believe or some say 6 some, 5, but i was given whatever is less. I get a special labor rate around $72 an hour.
The parts had to come direct from Jaguar, I was told no aftermarket ones are made. Not sure if it was just hoses or what, but anything under there that could end up leaking was done at the same time so they wouldnt have to go back again.
I was told its a pretty straightforward job, just time consuming.
#58
#59
#60
