Overpressure coolant | waterleak radiator
Hi, since a while I get a warning of coolant level too low and overheating engine. Also overpressure in the heater tank.
I thought about a head gasket problem but just found out there is water leaking beneath the radiator.
The radiator seems to be dry but the smaller part below is leaking. See picture.
Is this part of the radiator or is it an oil cooler?
Hope someone can point me in the right direction.
Jaguar S type - 2005 - V6 - 2.5
Last edited by Spencer4578; 08-13-2016 at 08:09 AM. Reason: additional inofrmation
Received 2,677 Likes
The part in front of the radiator is the air conditioning condenser unit, which from the looks of things, is also not in good condition. In order to remove the condenser and radiator, the air conditioning must be discharged by a shop having the proper equipment.
+1 on needing the radiator as the plastic side tanks are also prone to failure.
In addition, due to the age, since we do not know the number of kilometres, the coolant hoses should also be replaced and the thermostat renewed. The coolant expansion tank is another problem area, and should also be replaced whilst removing the radiator.
The following 2 users liked this post by NBCat:
Grant Francis (08-14-2016),
Jumpin' Jag Flash (08-16-2016)
aholbro1
02-14-2021 01:51 PM
