Owners manual 2002 s type 4.0 (pre facelift)
For researching OEM part numbers:
https://parts.jaguarlandroverclassic...-s-type-parts/
Once you have an OEM number, use it to search online from the many vendors out there. eBay can be a great source, too. Dealers often clean out old stock in big lots and third parties put the pieces up for sale individually.
Superseded numbers are usually still good, too. Often times part numbers are superseded for minor reasons, such as a new supplier, a change in color, or consolidation to fit multiple models.
Another version of the parts list can be found at the bottom of this page:
JagRepair.com - Jaguar Repair Information Resource
JTIS-Jaguar Technical Information Service-Shop Manual
In the top of the forum in the stickies?
JTIS
JEPC-Jaguar Electronic Parts Manual-Same as the dealer uses and be sure and check you part numbers using the last 6 digits of your VIN.
Jaguar Parts catalog
BUT JEPC is no longer usable because they killed flash player. We do have a solution in JPART which works fine and does show all the diagrams!
JPART to use JEPC
Don't find a 2000 version but would a 2001 version work? Should be pretty close?
2001 Owner Manual
JTIS
JPART to use JEPC
2001 Owner Manual
I’ve been in the same situation before. If you can't find the manual in the sticky threads, you might want to try the carmanuals website. They often have car owners manuals PDF versions available for download. Also, try contacting your local dealership; they might be able to provide you with a digital or physical copy.
