Oxygen sensor P1426 error
Hello All:
A quick and maybe dumb question. I have a P 1646 error on my 2003 3.0L Jaguar s-type. It notes in the forum chat say the code refers to Bank 1 (upstream). In the chat it notes this is on the firewall side of the engine. I have a shop manual but it refers to the heated O2 sensor as being called the H2OS sensor and shows them located on the top part of the cat converter intake. It only shows 2 sensor though and not the normal upstream/downstream 4. I am assuming from the shop manual I need to replace the one on the passenger side of the car right at the beginning of the cat converter. Is that assumption correct or I am missing something?
Thanks,
J
Thanks,
J
Was scratching my head about the title until I noticed something. The title of the thread says P1426, which doesn't exist for the S-Type. In the text of your original post, you said it was P1646, a whole different story. Is P1646 the actual code?
For P1646, details are here:
http://www.jagrepair.com/images/Auto..._OBD_II_R2.pdf
Of the four sensors, the faulted unit is bank 1 upstream. This will be on the right side of the vehicle when facing forward, on the US passenger's side. Each cat has an upstream and downstream sensor. The upstream sensor is located at the cat inlet, closest to the engine. As previously mentioned, make sure to get a quality brand such as Denso.
Sorry KR, my bad. Pulled up a pic from a buddies car I was helping with. The code is actually a P0037 H02 Heater Control Circuit Low Bank 1 Sensor 2. Shop manual reads, "Concern with RH catalyst monitor sensor." I take it that is the down stream sensor not the upstream sensor?
J
J
Majog (02-27-2023)
stevep10
12-31-2020 12:06 PM
heroooo
06-01-2015 01:09 PM
