P 1549-IMT question
Hi, all. I have a Jag stype 2005. Recently, I had check the engine light and scanned error code. It was P1549. I replaced IMT O-rings, but my jag still have the same error code. Do you have any similar experience or any suggestion? Please let me know. Thanks in advance.
jw, first off welcome to the forum.
Second, you really should follow proper forum protocol and go to the "New Members" section and introduce yourself. There are many benefits to doing so.
Third, please goto "User CP", "Edit Signature" and fill in your vehicle details "Save". It only takes seconds to do.
The following will aid in trouble shooting your IMT Valve, I believe you want to test the upper valve:
P1549. IMT Valve 1. CHECK THE RH IMT VALVE RESISTANCE
Disconnect the IMT valve electrical connector, PI30.
Measure the resistance between pins 1 and 2 of the IMT
valve.
Is the resistance 30 ohms?
Yes Goto B2
No
Install a new IMT valve. CLEAR the DTC. TEST the system for
normal operation.
B2 : CHECK THE POWER SUPPLY CIRCUIT TO
THE IMT VALVE 1.
Turn the ignition switch to the ON position.
Measure the voltage between IMT valve 1 electrical connector
PI30, pin 1 (NG) and GROUND.
Is the voltage greater than 10 volts?
Yes
Goto B3
Repair the circuit between the IMT valve 1 electrical connector
PI30, pin 1 (NG) and the Battery power bus 2.This circuit
includes the power distribution fuse box and the EMS control relay.
For additional information, refer to wiring diagrams. CLEAR the DTC.
TEST the system for normal operation.
B3 : CHECK
CONTINUITY OF THE IMT VALVE 1 SIGNAL WIRE.
Disconnect the PCM electrical connector, PI01.
Measure the resistance between the IMT valve 1 electrical
connector PI30, pin 2 (OY) and the PCM electrical connector PI01,
pin 38
Is the resistance less than 5 ohms?
Yes Goto B4
PI30, pin 2 (OY) and the PCM electrical connector PI01, pin 38 (OY).
B4 : CHECK IMT VALVE
SIGNAL WIRE FOR SHORT TO GROUND
Measure the resistance between PI30, pin 2 (OY) and
GROUND.
Is the resistance less than 10,000
ohms?
Yes
Repair the short to GROUND. For additional information,
refer to wiring diagrams. CLEAR the DTC. TEST the system for normal
operation.
No
Goto B5
B5 : CHECK IMT VALVE SIGNAL WIRE FOR
SHORT TO BATTERY
Connect the PCM electrical connector, PI01.
Check for a voltage at PI30, pin 2 (OY)
Is the voltage greater than 5 volts?
Yes Repair the short to battery. For additional information,
operation.
No
normal operation. If the DTC is repeated, INSTALL a new PCM. CLEAR
the DTC. TEST the system for normal operation.
Please post back your findings.
valve.
Yes Goto B2
No
normal operation.
THE IMT VALVE 1.
Yes
Goto B3
B3 : CHECK
pin 38
Yes Goto B4
GROUND.
ohms?
Yes
operation.
No
Goto B5
SHORT TO BATTERY
operation.
No
willburn (12-16-2012)
jwboys (12-19-2012)
joycesjag, previously, I checked wiring and everything except valve. I took out imt valve and checked resistance. Upper valve looked fine, but lower one showed no resistance. When I checked pin 1 with red of my multimeter and pin 2 with black, no resistance. When I checked pin 1 with black and pin 2 with red, the resistance was 6 mega ohms. I strongly doubt that something went wrong with the lower valve. So, I ordered lower valve and am still waiting for it. Thank you for your advice. After I fix it, I will post the result. Happy X-mas.
