P IIII no dtc definitions found
I have a 2005 s-type with 128k. It has been shifting strange lately, kind of hard shift I guess. Seems like a transmition problem of some sort. I had the car scanned at auto parts store and it threw the code
PIIII No DTC Definition Found
Does anyone know if thats related to the shifting problem?
you could also try this link which seems even better
http://www.gusglikas.com/images/Auto..._OBD_II_R2.pdf
brianflartey (09-10-2011)
P1111 means all good. The trans shifting may or may not produce a code. First thing I would try is going to a Jag or LR dealer (one that has a Jag tech) then have them do the trans adaptation clear then a readaptation. If this doesn't fix the concern then the nature of the concern must be checked. A trans module reflash may be needed. If all else fails and you need a transmission then call Mike at manhattaneuroparts.com. He can get a good price on a ZF reman trans. If you need any further help with it, give me a shout.
Also, the correct codes - see the FAQs here - have far more data.
barney100golf (09-12-2011)
I recently moved everything from that page over to www.jagrepair.com I will be redirecting things when I finish my transfers.
The following 2 users liked this post by barney100golf:
Gus (09-12-2011),
StypeRowner (09-12-2011)
trosty
26
12-18-2022 06:40 PM
al_roethlisberger
09-09-2015 09:14 PM
carcycle
09-07-2015 10:22 AM
car, code, definition, definitions, dtc, found, jaguar, manhattaneuropartscom, motor, p1111, reads, sats, scan, stype, vue
