P/S Leak 2005 STR
P/S Leak 2005 STR
I have a P/S leak/seep that is very small and does not drip on the ground. It looks like the P/S return hose is where the fluid is hanging off of. I have replaced this hose with no change. I added a second clamp because I don't trust the crummy spring clamps from the factory. This is the large hose that runs from the P/S reservoir down to the P/S pump mounted to the engine. But still leaks.
I still can't see fluid anywhere except this hose fitting.
Anyone else fix a P/S leak in this area?
That's a good point but the plastic reservoir is dry and the hose is only wet right at the curve where it connects to the pump. The pump is Aluminum and I tried to look at the steel nipple as I thought it might be leaking.
Another STR guy had a very strange coolant leak in the thermostat area. Turned out the steel nipples the hoses attach to are pressed into the Aluminum casting. His leak was between the steel tube and the casting. Only way to fix was replace the entire cast part.
tbird6
08-13-2024 07:50 PM
clubairth1
29
05-10-2024 12:57 PM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
rachelstr
09-03-2015 12:59 PM
