P0037 Fault Code Fix ??
P0037 Fault Code Fix and Porterfield Brake Pads ??
Hi all.
My apologies in adjargo vance for this question as I cannot seem to find a clear answer to the code as jargon is holding me back.
The problem code P0037 is Bank 1 sensor 2?
Questions:
1. On the 4.2 V8 NA, which side is bank 1? My car is a RHD.
2. Sensor 2? Is this the Oxygen sensor on the downstream side (rear side) of the cat convertor?
Sorry for the noob question but I have not located the solution map to the above on the forum?
The above is my last code to fix on the car as it is purring like a kitten. I have just finished the Valve Cover gaskets, and plug o-rings and now the plug chambers are perfect with no oil.
Also, has anyone had any experience (good or bad) with Porterfield R4-S Pad on a S-Type V8 2003 non R. I was planning to use new standard rotors but upgrade the pads to Carbon Kevlar to gain a little more bite! As this is my wifes car, it gets about 20 minutes twice a day of use. I thought that upgrading the rotors to something like Centric rotors would be a complete waste of money as the car bearly warms up each day. Your comments on these PADS would be greatly appreciated.
Kind Regards and thanks in anticipation of your comments.
Dirk
S-TYPE 4.2 (NON R) 2003
Questions:
Dirk
Last edited by Dirkman; 10-13-2012 at 04:51 AM. Reason: Additional content ad typo
Dirkman;
Good job fixing your problems!
Yes The second O2 sensor is generally after the cat.
You really need to get the JTIS and the JEPC. These are both free on this site. The instructions are at the top of the forum under the sticky threads. I am surprised you fixed all that without them!
Dirkman (10-13-2012)
Dirkman;
I will try to check now if it is before or after the Cat now.
Regards Dirk
Thansk for your comments.. Dirk
