P0171 Fuel Trim System Lean (Bank 1) ???
I seem to pop this code if i idle the car for a short time (say 20 min). Its not that big of a deal really, it doesnt show up at all if i drive it. Just shows up after idling for a bit. I can shut it off with my scanner. What usually does this or shall i ask, what would be the most common thing that contributes to this???
Lol yeah it's funny that when you have a P0171 and your car is running lean you will see a huge increase in your mpg sometimes over %35.. I would say you have a gasket or a hose that's cracked and is setting off the code.. Try the easiest thing first though: clean the MAF and reset.. Then start checking for leaks.. Eric
OkieTim
09-08-2015 04:48 PM
