P0171 and P0174
#201
![Icon Clapclap](https://www.jaguarforums.com/forum/images/smilies/icon_clapclap.gif)
I replaced the MAF....no change, except that the car seemed to need a slight delay after turning on the ignition and starting.
I was sure the codes were not being correctly thrown.
I did a ECU Hard reset, and it is no longer a problem. You can reset the ECU by detatching the two battery cables (Pos and Neg) and shorting them together for about 20 secs. Then reconnect them to the battery. It also reset my saved radio settings but that's ok. No cost and all done in 15 minutes.
#202
#203
Listen to JagV8. Get the car hooked up to a scanner tool and look at the fuel trims in real time. Then spray cleaner/propane what ever you want at the possible leak points while watching the fuel trims on the computer screen.
It's just a big guess where your vacuum leak is without watching the fuel trims.
clubairth1
29
05-10-2024 12:57 PM
Bob Gelston
09-14-2015 11:08 PM
OkieTim
09-08-2015 04:48 PM
NinoGrimace
08-26-2015 05:15 AM
