P0171 p0174 faulty PCV valve and pipe
My 03 STR recently threw some well known codes commonly related to vacuum leaks (p0171 p0174). I managed to spray some brake clean and locate the leak on the PCV valve line that runs from the valve past the blower and beneath to somewhere I cannot see. Although the pipe itself is not too pricey, I am not sure where it goes and exactly what else I must remove to replace the pipe. I've already removed the wipers, cowl, intake elbow, blower, and the cross structural bar at the rear of the vehicle engine bay. Before I go any further I attempted to do some research but there isn't a whole lot in the way of detailed info on how to remove that breather pipe on the STR. There are some other brittle pipes surrounding the area I am trying to get to so I thought I'd ask who has any detailed info on how to get this pipe removed or has done this procedure in the past? The pipe in question is number 1 in the diagram I have attached. Although I've been a member of the forum for 4-5 years, I've only read posts and never really posted one myself. Let me state that in case I need to say, do or include something else. Although I will make something happen one way or the other, any and all help is appreciated.
Yes, the hose definitely goes underneath the throttle body. I just am unsure of whether or not it attaches to throttle body. I have managed to repair the hose itself for the time being and the codes have seemingly went away. I will be taking apart the car this weekend to inspect further. Also still in the process of reading the manual Ducamon kindly suggested.
jnsju311
01-13-2016 09:27 PM
'05 STR
10-14-2015 12:50 PM
dshirley85
09-20-2014 09:19 PM
