P0172 and P0175
caveforce (11-05-2015)
Check the cats as they can cause rich running.
What is stored for the codes in the free frame data?
Sounds like the codes come back if cleared - how soon?
Have a look at fuel trims, too. Hot engine, parked, at idle & then rev to about 2500. (The idea is to get more data.)
Worth checking fuel pressure.
Received 2,263 Likes
1) Check the cats as they can cause rich running.
What do I check on the cats?
2) What is stored for the codes in the free frame data?
Where do I find the free frame data?
3) Sounds like the codes come back if cleared - how soon?
yes, the codes return within 50 miles driven.
4) Have a look at fuel trims, too. Hot engine, parked, at idle & then rev to about 2500. (The idea is to get more data.)
What are fuel trims and how do I check them?
5) Worth checking fuel pressure.
I am working on this.
At one point I replaced the lower O2 sensors. Would replacing the upper O2 sensors help with this?
You have a vacuum leak. The codes will return.
Look at the P/B hose connection to the manifold. It has an O-ring that will be hard and rotten by now. If it's not leaking, it will in the future.
Have you changed the under SC hose yet? Because that's an excellent time to repair that vacuum elbow too. Same stuff has to be removed.
The following 2 users liked this post by tbird6:
caveforce (11-05-2015),
Jumpin' Jag Flash (11-06-2015)
I know this sounds crazy, but check your battery. I was getting a series of strange codes when someone suggested that I check the battery. I was getting 11.5 volts across the battery with the engine off. The battery was 5 years old. I replaced the battery, reset the codes, and haven't had a problem since. That was about 2000 miles ago. I cannot explain why a marginally low battery voltage causes the problems.
The following 2 users liked this post by OkieTim:
Not sure what you are meaning here? I have followed existing posts and searches. Maybe I am not looking in the correct places which is why I am asking for direction. The last thing I want to do is send it to a shop so that they can keep it for another two months and charge me out the nose for their own mistakes.
The old days of 'hunt and peck and hope for the best' are pretty much gone.
The following 2 users liked this post by Mikey:
The following 2 users liked this post by Gus:
