P0174 - Restricted performance and sputter at wot
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
hey guy as yall know i just did the hose under the supercharger, everthing seemed to running fine in till i pulled in my driveway from work yesterday and the cel came on and restricted performace light came on, (i didnt wot yesterday but i have when i test drive it a day before) so i cleared the code, and omw home this morning sitting at a light around the corner the lights came back on, so i just "tried to do a quick accelerate but i sputtered, you guys have a clue what it might be??
and btw i had to change the fuel pressure reg cuz the vacuum piece broke off it..
shawn
shawn
Last edited by GGG; 01-19-2013 at 01:38 PM. Reason: edit typo in thread title so it appears in searches
Shawn, check fuel trims as jagv8 suggests. You likely have a vaccume leak. Restricted performance only allows up to 3k rpm then fuel cut-off. Check airbox, hose from airintake (just aft to airbox) to driver cam cover, crankcase ventilation line from pass. cam cover to its source on drivers side near brake booster, hose from brake booster to intake manifold near throttle body. A leaking intake manifold gasket. Leaking EGR hose and exhaust manifold tube. Do you hear a vaccume "hissing" sound? It's always nice to have a smoke machine handy.
your not talking a about the two small hoses (black with a grey line) are you?? if u are those are in place no leak.. maybe a vacuum diagram may help me..
hey guys just giving yall an update, looks like the leak i coming from the egr tube, i forgot it had broke, and my pops went to get it welded but the weld most of been poorly done, cuz i when turn on the air vent i smell a lil exhaust fumes coming from there, and when im at a light thats went the restricted performance light comes on and goes off when i start driving, but to ensure thats the only leak im going to my friends shop for a vacuum leak smoke test... ill keep yall updated
shawn
shawn
