P0174 -System too lean (Bank 2). Help me with the Freeze frame data.
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
My dreaded P0174 code popped up again. I thought I had this fixed when I found a cracked hose that connects the PCV Vacuum line into the intake. I replaced the rubber piece, cleared the code, and went a week and half before it popped up again.
I have inspected all the hoses according to post below and don't see anything wrong with the other hoses. This weekend I will take a better look when I do the 100,xxx mile maintenance on the Jag (replace sparks, coils, upper and lower intake seals, fuel filter, cabin and air filter, and oil change).
https://www.jaguarforums.com/forum/s...ics-faq-52720/
Can anything from the data below indicate the problem? Like perhaps the o2 sensor is bad?
Freeze Frame Data:
Fuel Sys 1 - CL
Fuel Sys 2 - CL
Calc LOAD (%) - 49.8
ECT (F) - 204
STFT B1 (%) - 25
LIFT B1 (%) - 6.2
STFT B2 (%) - 24.2
LIFT B2 (%) - 7.8
Fuel Pres (PSI) - 53.5
MAP(inHg) - 27.4
Eng RPM - 2055
Veh Speed (mph) - 21
IAT (F) - 89
MAP (lb/min) - 4.750
TPS (%) - 34.9
Any help would greatly be appreciated.
Freeze Frame Data:
Fuel Sys 1 - CL
Fuel Sys 2 - CL
ECT (F) - 204
STFT B1 (%) - 25
LIFT B1 (%) - 6.2
STFT B2 (%) - 24.2
LIFT B2 (%) - 7.8
MAP(inHg) - 27.4
Eng RPM - 2055
IAT (F) - 89
TPS (%) - 34.9
