P0304 - and yes... its still a good deal!
Old 04-19-2011, 02:48 AM
dbeardsl's Avatar
So - I just looked again.... via the same set of threads on this forum as the first time:
https://www.jaguarforums.com/forum/s...eplaced-27143/
I thought for sure I had it correct....
CAT
4 8
3 7
2 6
1 5
FAN
Is it the firing order I'm after, not the physical layout? I thought it was the physical layout...?
Old 04-19-2011, 03:55 AM
JagV8's Avatar
Received 4,534 Likes on 3,943 Posts
You don't have a 4.0
Ignore that thread. Stick with what I said please!!
Old 04-19-2011, 04:10 AM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
Ahh, now I see how you got confused dbeard...that's the 4.0L engine and numbered differently than your s-type - the 4.2L. Check it out below. now you know, and can investigate the correct cylinder. G'luck!
Old 04-19-2011, 04:33 AM
JagV8's Avatar
Yep. In the Vehicle Specifications, as I said he should get
Free to download
Old 04-19-2011, 01:28 PM
dbeardsl's Avatar
Where is the link to the specs? I found links to jus about everything else, but apparently NOT the right stuff
I purchased the JTIS (DVD) off eBay last night.....
thanks again for the help - I got it now. I'll give it another go
Old 04-19-2011, 01:58 PM
JagV8's Avatar
pah, it got left out of the FAQ
needs someone to add it LOL
https://www.jaguarforums.com/forum/a...achmentid=2914
Old 04-19-2011, 02:05 PM
H20boy's Avatar
I was unaware your s-type FAQ did not possess the Vehicle Specification document, I'll add it myself. When in doubt, I try to keep the very latest and informative documents in the xk8-xkr subforum FAQ thread, so if somethings missing in the s-type area, give that a shot!
Also, if there's something you'd like added to the FAQ, either send me a PM with the request (and any links necessary) and I'll get you taken care of.
If you would like the most accurate assistance, it is very helpful to place your vehicle information into your signature line, just look in your member control panel to set it up. Info like year, model, engine size, and other details like mileage can only aid in receiving more replies with the correct information. (thanks, h20boy!)
I just noticed this in your sigline jagv8... I suppose you're welcome is in order.
  #28
Old 04-19-2011, 02:46 PM
JagV8's Avatar
LOL!! Thanks, Matt.
Old 04-20-2011, 12:25 AM
dbeardsl's Avatar
amazing!!!! it worked - I've got a happy Jag!
thanks again for all the help!
While swapping out the plugs on the left bank, I noticed trace amounts of oil down along the bottom of the spark plug tubes. In #5, there was a fair amount. Looks like I may need to do a set of cam-cover gaskets and any seals that go along the plug tubes.
I'll tackle that one later. For now, its happy - running perfect, and no codes!
thanks for all the help!
Dave
  #30
Old 04-20-2011, 01:59 AM
JagV8's Avatar
Excellent! Thanks for the follow-up.
way2far
08-31-2022 09:26 AM
Sprayall
05-30-2021 08:13 AM
Pontsu
09-10-2015 12:25 AM
Sprayall
09-03-2015 07:49 PM
XJsc-guy
09-02-2015 11:43 AM
Quick Reply: P0304 - and yes... its still a good deal!
