p0305 AGAIN??
I have a bad misfire on a 3.0. I've changed the coil and plug twice, cleared the code and there is no change in the rough idling and obvious reduced drivability and my gas mileage is way down and I think it's made my cats go bad p0420? I assume that gas is being dumped which in turn could be giving me the p0420 but why would I have a misfire if I change plug/coil twice and it has a spark? Could It be the fuel injector, values or what? I'm kind of lost at this point.
Received 2,192 Likes
Well #5 on yours is middle cylinder drivers side, is this the 1 you changed. If so i would swap coils from adjecent cylinder to see if follows, but the connectors after that age break easy and then dont stay snapped onto the coil coming loose, i usually have to rig up tie straps to hold the connectors on. Barring all the previous you may have an injector leaking, but not common, but you can swap injectors too and see if the faults moves with them as well, at least you have a constant msifire, but yes you need to fix before the cats toast. If not already
Brutal may disagree, but I believe you have a faulty injector.. This very same problem happened in my Audi and for months it sounded like it had a lumpy cam and I could never figure out why.. Well turns out that my one of my aftermarket 870cc injectors had gone bad.. I was very pissed because they were $120 each, but I got the manufacture to send me a new one for free.. I would have toasted my cats as well, but my car didn't have any.. lol
No str, I agree, the injectors are the next loggical choise to look at. Theyre under the intake, and on their own assembly. You can remove the whole lower injection assemly, injectors and all. But if memory service me, the rails and injectors are installed at an angle very hard to r n r. Thats why we get them as an assembly, with new injecotrs. Someone else is gonna have to offer more aftermarket info, than I have at home right now
spahky86
08-02-2015 11:44 AM
Eman_usa
21
12-21-2012 02:20 PM
