P0400 keeps coming back / possible vacuumleaks
Hello guys, need some help with this returning issue. P0400 faultcode keeps coming back after erasing the code. It revers to the EGR-valve, but can also come from vacuumleaks / faulty MAF sensor.
done so far:
- Fuelsystem cleaner added, also directly on the EGR opening under the accelaratorvalve (i removed the complete unit)
- checked the EGR pipes for possible leaks
- replaced the MAF sensor for a new one.
- repairset placed for the mounting of vacuumline from manifold to brakebooster. (Copper Bush and o-ring)
- checked most of the hoses for possible breaks or leaks.
- fixed one connection of hose on the manifold to the breather on the valvecover.
what to do next?
the mil light turns on after a longer period of driving, sometimes long and sometimes shorter time.
when the light is on i have the feeling that the engine is not running so smooth as with no error. Also i have the feeling that the automatic gearbox shifts diverend with the p0400 error stored. But maybe the engine is taking a standard mapping when a fault is stored.
when i drive the car normally i noticed when giving a little gas on low revs, that the rpm is fluctuating/not stable. Changes up and down about 750 revs.
this could be another problem that has to do with the torque converter that is beginning to get faulty?
read someting about the bypass valve for the supercharger, the actuator can leak? In witch position is the valve open with vacuum on it or when in rest? Maybe i can bypass it to shut things out?
sorry for my bad english, al tips and hints are welcome.
Greetings,
Arian Vos
done so far:
what to do next?
Greetings,
Arian Vos
and also to see if you have made any head way, but because the exhaust gas is inert gas it will not show a lean condition if the egr valve is stuck open , unless a gaskit or egr tube is bad .
i have successfully remedied one XKR and one is STR egr valve ,
by removing the valve. And soaking them in carb cleaner. And manually moving the plunger whilst submerged. Then doing the same with WD-40 .
you will not clean the plunger stem Way you tried . As the flow is in the rong direction.
NBCat (09-19-2018)
Scan for correct MAP sensor function. In my case I was getting a P0400 EGR code (but strangely no MAP codes) because of faulty MAP function. The MAP sensor port is located next to the EGR port in the elbow. The EGR monitoring process commands full EGR during sharp deceleration (when driveability isn't affected) and if the MAP sensor doesn't pick up a pressure pulse you'll get the EGR code.
If anyone has been working in the elbow area previously they may have broken the MAP wiring connector. It's way too short and impossible to see. A sharp jerk on the elbow while removing it will do it.
Datsports (09-23-2018)
Ipc838
10-11-2018 04:07 PM
OldSpiceGK
01-30-2015 01:02 PM
JJ's Jags
03-11-2012 06:04 PM
