P0430 Cat threshold Bank 2 code, need some help.
hey guys, a few months back I changed all of my o2 sensors and cleared the code and it has not came back on until the other day. It was off for about 3-4 months. Would replacing the cat be the next step? I clear the code but it comes on after a few hours of driving. Some advice please, and cost and labor cost as well too. thanks guys.
Received 2,194 Likes
Leave the factory cats on and(ill say it again) go to O2 Simulator, mini catalytic Converter cel fix and buy the angled downstream 02 sensor extenders for the stype exhaust they're $30ea. Odb2 codes do not "magically" go away. They have to be cleared after repaired. Thats not to say that after so many key cycles a cel wont shut off, but the code stays. Iam not a fan of aftermarket cats unless youre selling the car. Reason, when i scap cats, oem fetch $40-80each from a cat recycler. Aftermarkets get $5! When i asked why. "they have very little precious metal in them and not worth much" and its the precious metals like paladiium etc that cleans the exhaust. So even though it may last a yr or more, they dont last long afterwards. Thats why most only have a 1yr warr. I have occassionally seen and bought stype oem cats for $500 on the web from differant sources, but no one that has them constantly at the price. So theres you some more info
The following 5 users liked this post by Brutal:
aholbro1 (11-27-2015),
Gus (05-23-2013),
joycesjag (05-23-2013),
NvmyJag (05-24-2013),
StypeRowner (05-27-2013)
Yes its a "test" piece to see if the sensor sees cleaner air when installed. If you leave it installed well thats your choice. Stypes are pretty easy to install. You only need a 22mm wrench, may need a 02 sensor tool if rusty. Put the car up on kackstands ,remove downstream 02's and install spacer and reinstall 02. Clear the code and thats it
P0430
I have been following this thread closely - have a S-type 2002 as well with the P0430 code. Have changed O2 sensors/new coils, plugs - code returned, used a bottle of Guaranteed to Pass Emission and RXS right before inspection almost two years ago and passed inspection. CELs been back, have been thinking of installing O2 simulator as well. Only question that I have as well - does anyone know if the inspection guy looks underneath the car for modifications with a hand mirror or is it something else (NJ) they are looking for ? If not I would go with Brutal's suggestion in a hurry .
sjgh - NJ looks under the vehicle with both a mirror going down both sides and a ground level camera and monitor - this will be easily picked up...
Last year my Jag was tossing the P0420 but the car ran fine so we reset the computer before taking it in for emissions. This year emissions caught it, Utah has changed the laws in 2013. Anyway Master Muffler wanted $1800 to remove and replace just the passenger side catalytic converter. He said it was a dealership part only even tho he had magnaflow equipment on display. I checked and magnaflow does make one to fit jags but it requires being fitted. Midas wanted to run expensive diagnostics blah blah blah. I was set to park it in the garage and just use the van. But luck would have it that I found an up and coming local mechanic shop and they not only put in a nice aftermarket unit but replaced the thermostat & seal, the orings on the fuel injectors, and washed her up to boot. Total bill $708. So you see guys it does pay to shop around!
