P0455 and P0456 at the same time?
Couldn't find very many posts from owners with this particular problem, so hopefully someone has a suggestion.
2005 S Stype VDP, 4.2L V8. Solved issues with misfires recently with new Iridium spark plugs and 2 new ignition coils, but P0442, P0455 and P0456 persisted.
So far I've installed a new OEM gas cap, cleaned the MAF sensor with MAF sensor cleaner and replaced the Evaporative Emissions canister purge valve resonator and valve assembly.
There is no fuel smell around the car.
I've cleared the codes and they reappear after 30-40 miles of driving.
Since the P0455 is a "large leak" and P0456 is a "small leak", maybe I don't have a leak at all, but a sensor issue?
Any ideas what to check next?
Thanks!
-H
Thanks!
-H
The link below shows the possible causes for P0445.
https://www.jaguarforums.com/forum/a...0455-p0455.pdf
It was posted by test point on the XJ forum and the link to this page is:
https://www.jaguarforums.com/forum/x...r-p0455-51210/
You seem to have done most suggestions already but it can't hurt to see this simple list to clarify your mind on the problem.
Finally below is a link to all Jaguar specific codes from Jaguar Online Club. Although you might not this need. I put it in for you anyway.
Jaguar Online Club: OBDII Fault Codes
Wolfy
05-28-2024 08:06 AM
