P0456 Evap Small Leak - But not really?
Old 01-01-2011, 09:31 PM
HIJaged's Avatar
It may be one or both Fuel tank flanges. The clamping rings are prone to cracking. Just had mine replaced last month.
  #42
Old 01-01-2011, 09:50 PM
pdr1966's Avatar
Default Thanks
Thanks for the great details and photos.
I am going to run out now before the temp drops tonight and check mine, this same symptom is on my TO DO list.....
Pete
  #43
Old 01-02-2011, 03:43 AM
JagV8's Avatar
Received 4,534 Likes on 3,943 Posts
Pete - you have code P0456 ?
  #44
Old 01-02-2011, 08:33 AM
pdr1966's Avatar
Default Pretty sure that was it, I remember the desciption closer
I'm pretty sure that was the code, I remember the description of 'very small' leak.
May take a listen around the canister today.
Pete
  #45
Old 01-02-2011, 08:44 AM
JagV8's Avatar
I don't know that you'll be able to hear such a small leak.
  #46
Old 01-02-2011, 09:23 AM
nixx's Avatar
It takes literally 2 minutes to pull that black plastic resonator off the vehicle. It's right up on top of the engine.. easy to get to. I'd check the underside of that part since it looks to be manufactured poorly and cracks along the edges.
  #47
Old 01-02-2011, 10:21 PM
Mafioso's Avatar
It's an extremely distinct
Hiss. I had mine with hood open at idle and his the same way and it's very distinct
  #48
Old 01-03-2011, 02:07 AM
JagV8's Avatar
OK. To others, don't rely on "no hiss = no leak", it just ain't so. However, "hiss = leak" is
  #49
Old 01-03-2011, 12:08 PM
nixx's Avatar
FYI- My car still has the loud hiss from passenger side.. and I don't have any CELs anymore.
  #50
Old 01-03-2011, 08:38 PM
pdr1966's Avatar
Default Pulled the canister
I pulled the Denso PA366 canister out of the assembly tonight.
Thought I might find it as a part alone, but no such luck.
In anycase, I will clean it thoroughly, determine what adhesives properly stick to it, inspect for cracks, and otherwise apply a bead of adhesive (epoxy?) around the body seam, and see if this fixes it - I did not listen for leaks before, as the car is kind of 'apart' right now.
It will be a while before I fix, and drive it enough to determine that this is resolved or not.
Pete
  #51
Old 01-04-2011, 01:48 AM
JagV8's Avatar
You should not have that hiss. There are plenty of places air can leak in, none of which should be left to go on leaking.
If you can't figure what needs fixing, read the fuel trims (and post them if you want help). Also check that both banks are running CL (closed loop).
  #52
Old 01-04-2011, 02:09 PM
hollywooddippa's Avatar
I have an '06 STR with the same issue and for some reason it's not set up the same as yours under the hood. I don't have a canister there.
  #53
Old 01-04-2011, 02:31 PM
JagV8's Avatar
I think yours will have changed to comply with the even tighter emissions laws. (Multiple changes.)
  #54
Old 01-04-2011, 02:39 PM
tbird6's Avatar
The 2006 STR finally got the VVT so that might be the reason for the difference??
  #55
Where would it be located on my car? I've gone through the same stuff. Swapped out a couple of fuel caps, inspected the lines, done a sniff test. I can clear the fault and after about five or six start-ups it will come back. The only exception is if I go on a long trip. I went to Utah last month and the light never came on the whole week I was there. When I got back, it was good for a a couple of days but as soon as I started my usual home to work drive it came back. I've taken several trips that were 150+ miles each way, and the fault doesn't show till I'm back. I always clear the fault before I go on a trip. It's the stop and go stuff that brings on the light.
Any ideas folks?
  #56
Old 01-04-2011, 02:40 PM
I'm sorry, what's VVT?
  #57
Old 01-04-2011, 03:30 PM
Jon89's Avatar
Received 4,369 Likes on 2,857 Posts
VVT is the acronym for variable valve timing....
  #58
Old 01-04-2011, 03:59 PM
androulakis's Avatar
I also noticed that the original Poster is from California. I know at least in to the mid / late 90's vehicles had "California" Emissions, and at some point there were a couple states added to the list. I remember 95% of speed parts saying 49 State legal.
I wonder if this is no longer the case, or if California still has stricter standards than the rest of the country. We only have a once every 2 yr OBDII code scan, only for vehicles over 5 years old. If no codes are present, and all the monitors are set ready, you're on your way for another 2 yrs.
They still do tailpipe testing on OBD1 Vehicles (like my '90 500SL), but they are talking about exempting cars over 20 years old (currently the exemption is at 25 years of age), so they can slowly weed out the last of the OBD1 cars sooner.
George
  #59
Old 01-04-2011, 06:19 PM
JagV8's Avatar
I think Brutal had a take on this code - have a look back. If you want (or need) to fix it, it won't necessarily be easy but also may require changing parts till you happen on the right one.
I'd think it may not set on higher speed driving for the obvious reason (small leak matters more when hardly using gas).
  #60
Old 01-04-2011, 09:24 PM
Originally Posted by Brutal
First is has nothing to do with competance. Ive smoke tested many a jags over the years and the only thing youll ever see on a smoke test is a large or gross leak. Small or very small leaks youll never see. And theyre never a gas cap. Gas cap are normally large and gross leaks. If i have someone that really wants to go after a small leak i tell them up front its gonna be a parts replacement mulitple visit issue. I start with the cheapest and what has shown to be the issue moreoften than not. Thats the fuel tank seals under the rear seat both sides. Theyre either round or flat depending on year and model. Then the cannister close valve, and then the purge valve. I have a 05 stype sitting in the back lot that needs a complete fuel tank since i found the leak on that 1 in the very top under the trans/propshaft tunnel. Thats not a serviceable part of the tank and its been here 3 months cause jaguar doesnt have a vender to make one yet. ....so my recommendation is quit spending money on the smoke test and code clearing at this point. Put tank seal in both side and lube well. Be prepared to move onto the next item without fuss if/when the light comes back on
If the fuel tank seals were leaking under the seats, would you smell gas? I don't have a gas smell.
Quick Reply: P0456 Evap Small Leak - But not really?
