P1000 Code Help
P1000 means your OBD II emissions check cycle is not complete (mis fire monitor, evap monitor, O2 sensor monitors, etc...) This code comes up when resetting the OBD II computer when erasing stored codes - sometimes when even changing the battery.
This is NORMAL!
Do not get your vehicle inspected with a P1000 - you will fail emissions testing due to the monitors being "not ready".
Drive your vehicle in various driving conditions - typically 150 - 200 miles of highway/city/everyday driving will be enough to set all your monitors to ready status. Keep in mind the evap monitor is the toughest to set but normal driving will set that monitor too.
Once all monitors are "ready" you should pull up a code P1111
Hope this helps!
This is NORMAL!
Hope this helps!
omcstan (01-19-2013)
This should help Link http://jagrepair.com/images/AutoRepa..._OBD_II_R2.pdf page 3
philwarner
25
06-26-2021 05:43 AM
