P1580 Electronic Throttle Monitor PCM Override
Guest
Posts: n/a
2000 S-Type 3.0 V6 - 122,000 miles w/ sport package
Got the Jaguar in the shop to fix the bad coil pack and the code it is showing is P1580 - Electronic Throttle Monitor PCM Override. Anyone seen this before? It has all the signs of a bad coil pack (misses when idling, rpm's jumpingup after the miss, real jerky acceleration especially at lower rpm's - it had this problem before the check engine light came on) but the code is showing different. Currently thinking about cleaning the throttle body... Any info would be greatly appreciated. Thanks.
Guest
Posts: n/a
Thanks for the info! I guess you can only get the tps sensor from a Jaguar dealer? And that would cause the car to buck during acceleration and seem like a miss while idling? It is much worse when the engine is under a heavy load at lower rpm's. Once you downshift, it smooths out some... Thanks again.
[quote=leroy1;518652]car will start but wont crank unless i spray gas into the intake to make it run when i stop spraying the gas it stop running fuel pump come on check for code and it came up with p1580 p1586 it will not stay running are crank on its on i got it from the auction the car run good as long as i spray gas into the throttle body also but gas in tank 2000 s-type 4.0
[QUOTE=leroy1;518728]Uh, fuel pump.... when turning the ignition on check for the woosh...sound by the back seat (passenger side) if you don't hear it you need to check: inertia switch, fuse, relay - if they all check - get ready to have your fuel pump(s) replaced.
leroy1 (05-25-2012)
leroy1 (05-25-2012)
leroy1 (05-25-2012)
leroy1 (05-25-2012)
abonano (11-02-2016)
Oh Bob, I think a noob was trolling and putting his garage name out here. As you saw, he posted to every "P1580 searched thread", hence the dinosaur threads being resurrected. I believe that he has been banned, I do not see any of his posts.
