P1580 Electronic Throttle Monitor PCM Override
Old 03-29-2008, 01:49 PM
Default RE: P1580 Electronic Throttle Monitor PCM Override
p1580 is for TPS circuit fault. looks like you need a new tps sensor.. i think you can get them separate from the throttle now.. before had to buy the whole $1700 throttle body. check the connector 1st.
Old 03-29-2008, 06:29 PM
It can cause those issues yes. You may have a bad coil still or lower breather hoses split. Sometimes will not set the light. Dealer can use GDS to check coil misfire count.
Old 03-30-2008, 11:41 AM
what is gds?
Old 05-24-2012, 11:15 AM
leroy1's Avatar
car will start but wont crank unless i spray gas into the intake to make it run 2000 s-type 4.0
Old 05-24-2012, 11:21 AM
jag79's Avatar
Originally Posted by jag_genius
what is gds?
....Maybe he meant IDS
Old 05-24-2012, 11:53 AM
leroy1's Avatar
[quote=leroy1;518652]car will start but wont crank unless i spray gas into the intake to make it run when i stop spraying the gas it stop running fuel pump come on check for code and it came up with p1580 p1586 it will not stay running are crank on its on i got it from the auction the car run good as long as i spray gas into the throttle body also but gas in tank 2000 s-type 4.0
Old 05-24-2012, 12:23 PM
tbird6's Avatar
leroy1;
Stop making random posts that are off topic. Please start a new thread with your problems. You will get better results.
Very confusing!
Old 05-24-2012, 02:37 PM
Received 8,180 Likes on 4,934 Posts
No, He said GDS!!!!
GDS is a hand held Jaguar scan tool.
bob gauff
File Type: pdf
Old 05-24-2012, 05:54 PM
Received 1,425 Likes on 1,067 Posts
[QUOTE=leroy1;518728]
Originally Posted by leroy1
2000 s-type 4.0 car will not run on it on unless i spray gas into throttle body
but shut down when i stop spray motor run find it has two code p1580-p1586
Uh, fuel pump.... when turning the ignition on check for the woosh...sound by the back seat (passenger side) if you don't hear it you need to check: inertia switch, fuse, relay - if they all check - get ready to have your fuel pump(s) replaced.
leroy1 (05-25-2012)
Old 05-25-2012, 05:02 AM
JagV8's Avatar
Received 4,538 Likes on 3,947 Posts
Or fuel filter. And I agree - stop the random posts!!
leroy1 (05-25-2012)
Old 05-25-2012, 05:11 AM
plums's Avatar
Received 2,184 Likes on 1,624 Posts
That's right. You tag posted on a four year old thread. Your duplicate, self-bumping posts have been deleted.
leroy1 (05-25-2012)
Old 05-25-2012, 07:05 AM
Amen to that!
leroy1 (05-25-2012)
Old 05-25-2012, 04:45 PM
leroy1's Avatar
check fuel pump for woosh sound is there gas is coming out of fuel rail bleeder vale. 2000 s-type 4.0 v8- 158,000 miles. code p1573-p1580-p1886-p0180-p1576
Old 11-02-2016, 12:41 PM
JagV8's Avatar
You're looking to get BANNED at this rate.
Old 11-02-2016, 03:19 PM
Maybe he banned himself. The last post that I see is over 4 years ago.
bob
Old 11-02-2016, 03:29 PM
JagV8's Avatar
I think the mods have removed the ones I reported
Sanity is restored, thanks guys!
abonano (11-02-2016)
Old 11-03-2016, 08:23 PM
I have no idea about sanity as I did not see the INSANE.
Only really old posts.
bob
Old 11-03-2016, 08:48 PM
joycesjag's Avatar
Received 1,712 Likes on 1,213 Posts
Oh Bob, I think a noob was trolling and putting his garage name out here. As you saw, he posted to every "P1580 searched thread", hence the dinosaur threads being resurrected. I believe that he has been banned, I do not see any of his posts.
Quick Reply: P1580 Electronic Throttle Monitor PCM Override
