P2096, P2098, P1646, P1647 codes
Relays
Good result. I had similar problem with my jeep GC. The relay for the auto gearbox power supply was the final suspect after the box checked out ok. I pulled the relay apart and found corrosion on the switch contacts. A few passes with 180 paper cleaned it and the box worked perfectly for 5 years...
so far no such problems with my 99 S v8..
Paul
Paul
kr98664 (09-02-2021)
So this morning I went an swapped the R3 with the R20- the starter relay- figuring if something went wrong with it I would know very quickly.. This weekend will provide with temps around 98-99 to see if they return.
As a question, you had earlier said "look again at figure 01.7" from the attached. I went and looked and could not find anything related to "figure 01.7" What were you referring to?
Tom
http://www.jagrepair.com/images/Auto...cal-2005on.pdf
Not to be too nitpicky, but a preposition is nothing to end a sentence with...
Thanks for humoring me, but I'm not sure the starter relay is the best donor. Yes, it obviously works if the starter engages, but the contacts may have a good degree of wear due to the hard work this relay does repeatedly. I'd suggest R6 as a better donor. That's the wiper high/low relay, which hopefully doesn't see a lot of usage and is closer to new condition.
Have you considered moving to a cooler climate? Seems that would solve the problem.
The wiring diagram is a 200 page PDF. See pages 50-51 for figure 01.7:
TBB
The following 3 users liked this post by jazzwineman:
#28
#30
#31
JayJagJay
10-24-2016 09:11 PM
dvsadam
12-31-2015 08:27 AM
jazzwineman
07-20-2015 02:55 PM
BmwR60
04-17-2013 06:28 PM
Gus
10-27-2010 09:21 AM
