P2099 Post Catalyst Fuel Trim System Too Rich (Bank 2)
Hello everyone! Ok....I have a 2006 s type sport - 3.0 112000km on her...
recently have had the following done - (past few weeks)
Imt O Rings
Inlet Gaskets or seals...
New Plugs
replaced #2 bank 2 sensor
replaced mass air flow sensor
replaced #1 sensor on bank 2
All other codes have gone away...but this 2099 keeps turning on my engine light....it is driving me CRAZY...
Thank you.
Imt O Rings
New Plugs
Thank you.
Imt O Rings
New Plugs
Thank you.
Imt O Rings
New Plugs
Thank you.
The reason the fault is still present after your rectification is because the sub-feedback* adaption value will not have had time to re-adapt after the new sensors are fitted. The procedure to get around this situation is to disconnect the battery for about 10 minutes to reset the sub-feedback adaption values. This procedure will reset all adaption values and so the ignition should be cycled (on for 10 seconds, off for 10 seconds) a couple of times to allow closed throttle learning to happen.
It's worth a try.......
Jumpin' Jag Flash (10-14-2015)
Thank you for your reply. So clear the code first...then disconnect the battery for 10 min? A few questions regarding this....
Will I have to reprogram my blue tooth, radio and seats - also will I need the code for the raido to get it to work? Any other surprises when disconnecting the battery?
I appreciate the help...thank you.
(I have the touch screen nav in my car)
Good on all other points, though if the radio is improperly set for a non-US/Canada market, he may need a code. hat does happen sometimes.
Also, once the battery is re-connected, wait 30 seconds before turning on the ignition so the Climate Control can have time to re-index the mode doors.
Cheers,
I know this is a really late reply (years), but I went overseas on a work assignment and left the issue unresolved. A month ago I replaced all 4 oxygen sensors and the code and engine light are resolved (even though no specific codes were thrown indicating a bad sensor). Thank God it wasn't the cats.
I've tried on my '05 STR and no, they stayed. I have a scanner but decided to try just for the heck of it. I also found it interesting that the readiness monitors were set after only a short drive, most cars take between many miles and eternity.
