PARK BRAKE FAULT
Guest
Posts: n/a
PARK BRAKE FAULT
I Have an 03S type R. I replaced the passenger rear wheel bearing. Im now getting a 'PARK BRAKE FAULT' message on my display as well as my brake light lit. I have read in previous post that when you replace pads you must reset the module or recaliberate the EPB. I would assume since I did remove the Parking brake caliper than all this must be done as well. How do you reset the EPB module? or how do I get the message and chimes to go away???? fyi everything worked perfectly before I replaces the wheel bearing.
Thanks!
Thanks!
neruda
10-18-2015 01:19 PM
