parkbrake fault -abs falt-Gearbox fault-dsc not available
Guest
Posts: n/a
forgot my sunroof open and rained inside my jag s type 03 (badly socked) it throwing all parkbrake fault -abs falt-Gearbox fault-dsc not available - battery light error
i have replaced the battery it starts fine sometime with no error but shift from park to reverse all the error will appear (rough shift_
all the gauge dashboad stop workin stop work
code reader gives [P1637][P1638][P1646]
the car still drives smoothly
please help
please help
P1637 and P1638 could be due to problems with the car's internal communications network ("CAN"). Ideally you'd dry the car out thoroughly but with care (no excess heat!) - maybe using A/C or the like. Gentle heat in your garage (if you have one)?
Think of a PC which gets wet, along with its keyboard, mouse, printer, scanner etc.
Bad news, but with power off and careful drying all might be all right.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
dmatthewman
09-30-2015 10:10 AM
