Parkbrake Fault warning.
#61
New motor and module arrived
I DC tested new motor it show 1 ohm across power wires red/green
Which was different to the 5.5 across my existing motor.
So I plugged the new motor in and checked to see if fault warnings had cleared on the dash, they had not.
I then fitted the new module with the new motor still plugged in, connected the battery again, and checked the dashboard, all warnings and faults had gone, including on the code reader.so I set about installing the new motor, followed WSM instructions apart I did not disconnect the propshaft, bit of a fiddle but the entire job took 2.5 hrs.
I then did the EPB rest procedure.
Doing the work myself saved £200 in labour costs.
I took a few pics to ensure all went back ok.
This was relatively easy in all honesty.
Thanks to everyone who sent advice/instruction and replied to plea for help.
Regards all Tony
Regards all Tony
Cheers,
#62
UPDATE**
Just an update, I bought the BOSCH 49-850B at pep boys less than 100$ -
Result all faults gone let sit still no faults, runs great! Actually now when the car sits for 2 days in the cold I notice a MUCH quicker startup, instead of a 2-3 crank it's near instant start upon key start dead cold. I can tell a very distinct difference. NOW MIND YOU THE OLD BATTERY TESTED IN THE ACCEPTABLE (GOOD RANGE) SO THE MORAL IS JUST CUZ IT TESTS OK DOESN'T MEAN IT IS STILL TOO WEAK FOR THIS CAR, BATTERY HAS TO BE TOP NOTCH SHAPE TO FUNCTION WELL! IM VERY HAPPY , THANKS YOU GUYS FOR THE ADVICE TO CHANGE BATTERY!!
#63
Received 2,190 Likes
update**
just an update, i bought the bosch 49-850b at pep boys less than 100$ -
result all faults gone let sit still no faults, runs great! Actually now when the car sits for 2 days in the cold i notice a much quicker startup, instead of a 2-3 crank it's near instant start upon key start dead cold. I can tell a very distinct difference. Now mind you the old battery tested in the acceptable (good range) so the moral is just cuz it tests ok doesn't mean it is still too weak for this car, battery has to be top notch shape to function well! Im very happy , thanks you guys for the advice to change battery!!
goges
10-05-2015 04:53 PM
dmatthewman
09-30-2015 10:10 AM
