Parking Brake not releasing.
About 6 months ago the parking brake would sometimes fail to release after I had washed the car and let it set in the garage. Then it would not release at all. I called the Jaguar Dealer Service manager, he said to disconnect the battery for 15 minutes. It worked for about a month. Then the same thing again. I called the Dealer again, I got a female serviceperson, told her my problem. She asked how old the battery was. Original battery, 6 years. She said to replace the battery even though it seemed fine, started the car after setting a couple of weeks, no problem with the battery. She told me that even though it seemed fine, the battery did not have enough power to release the parking brake. She recommended an Interstate Battery number MTP93.
With skepticism I replaced the battery. Problem solved, no parking brake release failure.
Jack
Jack
Fumes from the battery are vented in the vehicle interior and also possible vent of battery acid into the trunk of the vehicle. Not a good thing.
Look on the top or side near the top of the battery, you will see a small round plastic tube on the side of the battery. Hopefully it will have a small tube running from the battery to the exterior of the vehicle.
Jack
Jack
ONEsicJAG (08-11-2013)
neruda
10-18-2015 01:19 PM
Pluckie
10-03-2015 07:57 AM
