Parking Pawl Issue Workaround
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
So any of you that have the issue where it's hard to pull the car out of park to the point where it feels like you have to pull so hard that you're going to break something I have found a workaround that has been working 100% of the time without fail...
it's quite simple actually.... all you have to do is before you put the car in park, drop it into neutral first... don't just zoom through the gears, but actually select neutral for a second and then put it in park (I also use my hand brake when parking as well) I back into my drive all the time so when I'm ready to put it in park it goes like this;
-Foot on the brake
-Go from 'R' (or 'D') to 'N'
-Wait to hear it drop out of gear
-Put it in park
-Apply hand brake
-Lift foot off brake
-Turn off car
Not once since I've started doing this have I had my car stuck in park
hope this info helps someone
-Foot on the brake
-Put it in park
-Apply hand brake
-Turn off car
Received 2,631 Likes
-Foot on the brake
-Apply hand brake
-Let car settle onto hand brake
-Foot back on brake
-Shift to 'P'
-Turn off car
-Foot off brake
I realize this adds an extra cycle with the foot brake, but it soon becomes second nature. This procedure makes the hand brake the primary restraint when parked. The transmission becomes a secondary restraint and avoids all problems with the park pawl getting stuck as it is never loaded unless the hand brake slips.
Rlover
03-30-2016 10:04 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
