parting out 2001 jaguar s type
What engine do you have in your S-Type? There are some people looking for DCCV and solenoids among other things. It might be useful to post pictures of your engine as well as the intact parts of the interior for reference.
Well, you might have to get a couple doors.... But the ones from a Lincoln LS will fit, right?
Y'all are making me show my bad side.........
jaguar s type
yeah i will soon post pic of the motor and the inside.
i dont know if the doors will fit from a lincoln LS, does anyone know for sure.
No they don't.... It was a joke, so let me explain.... The Lincoln and the Jaguar shared a platform..Then each went their own way with the design. There are some shared components, but the assumption is that everything is common.. So, it was a bit of sarcasm based on a lot of posts here..... Sorry 'bout that...... I'll be a good boy.....
I would not purchase a used DCCV. They will all fail given enough time. The seals on the solenoids leak and flood the inside of the solenoid. Once any fluid gets by these seals the corrosion has started and it's only a matter of time before they start sticking and finally they will get stuck permanently in any position from fully open to fully closed.
Good one on the Lincoln LS door!!!!
turtle-wax once a year compound, and some replica ls doors.
OP for real, some info is needed on the car such as motor. there are valuable parts on there like throttle body, some coils and stuff. the actual motor. information sells.
jaguar s type parts
here are some pics of the motor and the interior. hope that will help. i could gave you the vin# if you need to check the part numbers or stuff like that. thanks
Post the VIN, year, mileage, engine size, whether sport, SE, etc, any options fitted (upgraded sound, sat nav, which wheels, etc etc) - basically anything to help people.
Well...
I am looking for the rear seat cupholders for my 2001 s type. These are the ones that are built into the seat and are spring loaded. If those are in tact let me know.
I don't suppose you would crawl under there, remove the trans. cover, remove the solenoid block and send it too would you?
jaguar s type parts
yeah i have the rear seat cup holders and the transmission is gone already
jaguar s type parts
yes i have it and i could do it for $50
sorry its gone already
Hey! I know this sounds a little specific, I am trying to get the trunk lid popper button cover between the word "JAG 'O' UAR":
the actual 'kitty' head thing popped out the other day... Better than my buddys CTS dropping it's whole reverse light plastic lol
